The admin interface is broken, and IE8 it shows couple of javascript errors. To strat with for first hours it worked fine, but suddenly the css/style file might have get courpted.
I had just finished with Master and hpme pages for my site, so I don't think it is related to my changes :).
Does any one know how to restore the css/style of admin interface?
I hade the same issue and ended up just restoring a backup. I don't know what happened, but I could not navigate to any of the other sections other than "content". Also a full "republish" has broken my entire site when using the new schema. Changing the config to old schema and republish EACH docment fixes the problem.
I am eager to use the new schema, but find it (at least on my upgraded sites) very buggy to say the least.
I had the same issues, I upgraded from 4.0.x using the advice here . It turned out that I forgot to add ~ to the following entries in the appSettings section of the web.config: umbracoReservedUrls, umbracoReservedPaths, umbracoContentXML, umbracoStorageDirectory and umbracoPath as they now start with a tilda (~) . And change <add key="umbracoStorageDirectory" value="/data" /> to <add key="umbracoStorageDirectory" value="~/App_Data" />.
Yup.. another example of where the documentation is lacking or not consistent with regard to the REQUIRED upgrade procedures. I beat myself to death trying to get upgraded.
Thanks for replying all. Finally I take advice from you all and just done a clean install of 4.5.2.
Luckily it was early stage of project, where I have not done enough development. I tried some other stuff as well, try to upgrade to latest but no luck.
So my advice is to stick to a single version and complete the project first, then think of upgrade. :D.
Admin UI Interface is broken 4.5.2
Sanjay
I tried and reinstall 3 times, but after couple of hours it again behaves same. It is frustrating as I am unable to develop further with out admin UI.
Does any one have any solutions? Please I need this sorted out urgently.
Sanjay
Can any one mark this as closed post please?
Sanjay
