  • Kasper 9 posts 29 karma points
    Aug 29, 2010 @ 18:35
    Kasper
    Umbraco: Asp.Net Ajax usercontrol javascript error in IE and not FF
    Hey All
    Hi have a problem i cant seem to fix, hope you guys can help me find the problem...
    You can visit: http://sodamand.criders.net/Kategori/sodavand.aspx and you will se that in IE an  Javascript error "Sys.Extended.UI" witch not is raised in FF and the Page works fine...
    I have search google for a solution but without luck...
    Best regards
    Kasper
