Using Umbraco 4.0.3, I cannot get all symbols displayed correctly. In particular, I need to use the trademark symbol TM (™) Whatever method I use to insert or define this symbol, it is not displayed as TM - I just get a 'T' character. Any clues...?
Displaying inserted symbols
Thanks.
OK, found the fix in an old topic at http://forum.umbraco.org/yaf_postst7024_Version-4-and-TinyMCE-entity-encoding.aspx. Now working fine.
