I have set permissions by the book to both c:\windows\temp and all the files in the Umbraco folder.
But nodes are still not showing up!
If I do an IIS Reset it will work for about 2 days, then the same problem.
I am running thsi site on IIS7 on Windows Server 2008.
I get this in the log:
At /umbraco/tree.aspx?rnd=f5fdb9dc-37e3-4bcd-8462-8a2ab5131bb6&id=-1&treeType=content&contextMenu=true&isDialog=false (Referred by: http://www.tidbecks.se/umbraco/TreeInit.aspx?app=content): System.IO.FileNotFoundException: Could not find file 'C:\Windows\TEMP\vydyigvf.dll'. File name: 'C:\Windows\TEMP\vydyigvf.dll' at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at Microsoft.CSharp.CSharpCodeGenerator.FromFileBatch(CompilerParameters options, String[] fileNames) at Microsoft.CSharp.CSharpCodeGenerator.FromSourceBatch(CompilerParameters options, String[] sources) at Microsoft.CSharp.CSharpCodeGenerator.System.CodeDom.Compiler.ICodeCompiler.CompileAssemblyFromSourceBatch(CompilerParameters options, String[] sources) at System.CodeDom.Compiler.CodeDomProvider.CompileAssemblyFromSource(CompilerParameters options, String[] sources) at System.Xml.Serialization.Compiler.Compile(Assembly parent, String ns, XmlSerializerCompilerParameters xmlParameters, Evidence evidence) at System.Xml.Serialization.TempAssembly.GenerateAssembly(XmlMapping[] xmlMappings, Type[] types, String defaultNamespace, Evidence evidence, XmlSerializerCompilerParameters parameters, Assembly assembly, Hashtable assemblies) at System.Xml.Serialization.TempAssembly..ctor(XmlMapping[] xmlMappings, Type[] types, String defaultNamespace, String location, Evidence evidence) at System.Xml.Serialization.XmlSerializer.GenerateTempAssembly(XmlMapping xmlMapping, Type type, String defaultNamespace) at System.Xml.Serialization.XmlSerializer..ctor(Type type, String defaultNamespace) at System.Xml.Serialization.XmlSerializer..ctor(Type type) at umbraco.BusinessLogic.Utils.SerializableData.Serialize(Object objDeserialized, Type objectType) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\businesslogic\Utils\SerializableData.cs:line 43 at umbraco.cms.presentation.Trees.XmlTree.ToString() in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\presentation\umbraco\Trees\XmlTree.cs:line 73 at umbraco.cms.presentation.tree.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\presentation\umbraco\tree.aspx.cs:line 52 at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at umbraco.BasePages.BasePage.OnLoad(EventArgs e) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\businesslogic\BasePages\BasePage.cs:line 287 at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
have you tried IIS reset?
Yes, but that only solved the problem on short terms.
have you tried using application pool identety insted of networkservice?
No nodes showing up in backend
