When I click Insert image in my RichText editor I get a dialog
How can I select an image ? - it appears that I'm only able to type in the URL.
Before I upgraded to version 4.5.1 I was able to browse for the image
Have I missed something in the upgrade ? - or ...
/Paul S
did you come right with this - I have the same
Yes I did.
The upgrade guide I have downloaded says nothing about copying the config files - but the link to the upgrade guide on Codeplex does.
In the TinyMceConfig file located int the config folder must be updated. It must contain 'umbracoimg' but not 'advimage'
- experience learned the hard way - hope it helps
thanks - sorted it out!
Upload image
Media picker is missing in Richtext Editor
/Paul S
Yes I did.
/Paul S
