Hi!
I've noticed that some labels isn't translated in the UI of 4.5.x. Where do I submit translations for my language? Example: "Export to .NET" is displayed as "[exportDocumentTypeAsCode]" when you rightclick on Document types.
cheersPatrik
I think you should be able to do it here:
http://umbraco.org/documentation/language-files
But it seems that they have not been updated to the latest version of the language files, since the key you mention is not present there.
However, you could go here:
http://umbraco.codeplex.com/SourceControl/changeset/view/77133#904941
And copy the xml you want to edit, and submit that as a patch?
Thanks!
I'll take a look at the XML at codeplex.
Untranslated items in umbraco 4.5.x
Hi!
cheers
Patrik
Thanks!
