  • Daniel.S 50 posts 135 karma points
    Sep 14, 2010 @ 14:48
    Daniel.S
    v4.5.2 TinyMCE not displaying, JS Error
    Having an issue on my Umbraco 4.5.2 instance where fields of type "Richtext editor" don't display the editor or even the textarea in the back-end.
    It's running on IIS under Windows 7,
    If I go to http://www.website.local/umbraco/plugins/tinymce3/tinymce3tinymceCompress.aspx, I get the following error, not sure if it has any bearing on this issue:
    Webpage error details
    User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E)
    Timestamp: Tue, 14 Sep 2010 11:02:45 UTC
    Message: 'tinyMCE' is undefined
    Line: 252
    Char: 1
    Code: 0
    URI: http://www.website.local/umbraco/editContent.aspx?id=1063
    Also, loading Umbraco in IE yields the following JS error:
    Line: 252
    Char: 1
    Code: 0
    I've tried with all of the different browsers, the same thing happens.
    I had the site (4.5.2) running under VS2010 and Cassini previously, and I then did a fresh install of 4.5.2 just under IIS as normal and imported the package of content, document types, macros, xslt files, etc from the first site. I think the problem started occurring straight away on the new site.
    Any ideas anyone?
    Sep 15, 2010 @ 01:42
    Daniel.S
    Solved this by setting up a new Umbraco instance and migrating all my content, doctypes, etc over to it.
