I post this because I have tried most topics on this forum and can't get any of them to work. Someone else designed and set up my site and I am trying to add to it myself.
I am trying to embed a simple Silverlight media player on a web page (my site runs Umbraco version 4.0.2 if it matters). I currently have a Windows Media Player embedded pulling out of publishing points (on demand and live) on a remote Media server. The player works well for anyone who can play it but there are way to many people who can't play it (i.e. Mac users). I heard that Silverlight would work on many platforms, plus it looks great, but I can't seem to set it up right. None of the packages will intall. I have tried using the videoplayer.xap and .js methods but to no avail.
I usually don't like to bother until I am frustrated so here i am.
The only access I have to the website is through ftp so I don't really know. I'll check with the hoster (slow to respond thus me ending up doing many things on my own).
I should mention that in one of my attempts I was able to see a white box that says "Silverlight" when I right-click. Means anything?
That means the web server has been configured correctly (MIME types were added) and you have installed Silverlight runtime. I guess it's the code/package that you installed.
Alternatively, I found this jwplayer that uses javascript files and a .xaml file.
I have put the 2 .js files and the .xaml file in my site's folder (via ftp) and now I have the following javascript to setup:
<div id="myplayer">the player will be placed here</div>
var elm = document.getElementById("myplayer");
var src = '/wmvplayer.xaml';
var cfg = {
file:'mms://ip_address/publishing_point',
width:'320',
height:'240'
var ply = new jeroenwijering.Player(elm,src,cfg);
</script>
The problem is that if I put this in html in my text document I get nothing (except the "the player will be placed here"). I tried using an xslt and it worked (!!) but I would have to create a separate macro for each video I want to insert? That doesn't make sense i think.
How do I insert the script (with different cfg) everywhere I want to insert a video?
Put the script in the XSLT (for guys prefer C# coding - like me - it would be in .ASCX) then make the file as variable. Then add a property in the Document Type for the user to fill the file link value. And then use the property value to fill the variable in XSLT.
Alright I played a little and tried to make variables. Here is what I've done:
I made location (which would be mms://...), width and height variables in the modified xslt below and added the parameter in the macro.
When I insert the macro in my content, a widow pops out and asked for the 3 parameters but it doesn't seem to work. Anyidea why? Should I post this issue as a separate issue?
code:
<!DOCTYPE xsl:Stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
<xsl:variable name="location" select="/macro/location"/>
<xsl:variable name="width" select="/macro/width"/>
<xsl:variable name="height" select="/macro/height"/>
<xsl:template match="/">
var src = '/media/28447/wmvplayer.xaml';
var file = '$location';
var width = '$width';
var height = '$height';
var ply = new jeroenwijering.Player(elm,src,file,width,height);
</script>
</xsl:template>
</xsl:stylesheet>
I finally got it to work. The final code is below. I used urllocation as my variable and the property is in my document type. i then insert the macro into my richtext editor.
<xsl:stylesheet
version="1.0"
<xsl:variable name="urllocation" select="$currentPage/data[@alias='urllocation']"/>
var cfg = {
file:'<xsl:value-of select="$urllocation"/>',
width:'320',
height:'240'
</script>
</xsl:template>
</xsl:stylesheet>
Silverlight Player Won't Play
Thanks in advance for your help and patience,
Christophe
Hi Christophe,
Have you registered .xap MIME type?
This is how to do it:
http://learn.iis.net/page.aspx/262/configuring-iis-for-silverlight-applications/
Ferry
Hello Ferry,
Thank you,
Christophe
Alright I'm back with no answer on the .xap .
<div id="myplayer">the player will be placed here</div> <script type="text/javascript"> var elm = document.getElementById("myplayer"); var src = '/wmvplayer.xaml'; var cfg = { file:'mms://ip_address/publishing_point', width:'320', height:'240' }; var ply = new jeroenwijering.Player(elm,src,cfg); </script>The problem is that if I put this in html in my text document I get nothing (except the "the player will be placed here"). I tried using an xslt and it worked (!!) but I would have to create a separate macro for each video I want to insert? That doesn't make sense i think.
Thanks you,
Christophe
Hi Christophe,
Ferry
Pardon my ignorance but how do you do that? Here is the xslt code I have that worked when I inserted the macro:
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE xsl:Stylesheet [ <!ENTITY nbsp " "> ]> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" exclude-result-prefixes="msxml umbraco.library"> <xsl:output method="xml" omit-xml-declaration="yes"/> <xsl:param name="currentPage"/> <xsl:template match="/"> <div id="myplayer">the player will be placed here</div> <script type="text/javascript"> var elm = document.getElementById("myplayer"); var src = '.../wmvplayer.xaml'; var cfg = { file:'mms://ip_address/pub_point', width:'480', height:'360' }; var ply = new jeroenwijering.Player(elm,src,cfg); </script> </xsl:template> </xsl:stylesheet>I would like to make the file, width, and height variables and have the choice to enter the values when I insert the macro (?).
Thanks again.
code:
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE xsl:Stylesheet [ <!ENTITY nbsp " "> ]> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" exclude-result-prefixes="msxml umbraco.library"> <xsl:output method="xml" omit-xml-declaration="yes"/> <xsl:param name="currentPage"/> <xsl:variable name="location" select="/macro/location"/> <xsl:variable name="width" select="/macro/width"/> <xsl:variable name="height" select="/macro/height"/> <xsl:template match="/"> <div id="myplayer">the player will be placed here</div> <script type="text/javascript"> var elm = document.getElementById("myplayer"); var src = '/media/28447/wmvplayer.xaml'; var file = '$location'; var width = '$width'; var height = '$height'; var ply = new jeroenwijering.Player(elm,src,file,width,height); </script> </xsl:template> </xsl:stylesheet>Thanks,
Christophe
Hi Christophe,
You can use this page as reference:
http://umbraco.org/documentation/books/xslt-basics/using-variables-and-parameters
So, your code must be changed to be something like this:
<xsl:variable name="location" select="$currentPage/data[@alias='location']"/>
and then like this when using the variable:
<xsl:value-of select="$location"/>
Ferry Thank You!
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE xsl:Stylesheet [ <!ENTITY nbsp " "> ]> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" exclude-result-prefixes="msxml umbraco.library"> <xsl:output method="xml" omit-xml-declaration="yes"/> <xsl:param name="currentPage"/> <xsl:variable name="urllocation" select="$currentPage/data[@alias='urllocation']"/> <xsl:template match="/"> <div id="myplayer">the player will be placed here</div> <script type="text/javascript"> var elm = document.getElementById("myplayer"); var src = '/media/28447/wmvplayer.xaml'; var cfg = { file:'<xsl:value-of select="$urllocation"/>', width:'320', height:'240' }; var ply = new jeroenwijering.Player(elm,src,cfg); </script> </xsl:template> </xsl:stylesheet>Thank again,
Christophe
Glad to hear that.
You're welcome.
