I have been following this artikel http://our.umbraco.org/wiki/how-tos/enabling-the-%27template%27-plugin-for-tinymce to get the templates to work in the editor and it works fine.
But how do I make more than one template?
In the text-editor where I pick the template is the name of the templates in a dropdown, but where do the name come from.
I thorght it came from this line (title : "Two Column",)
<config key="entity_encoding">raw',template_templates:[ { title : "Two Column", src : "/home/TwoCol.aspx", description : "Two Column layout" }], template_popup_height : '400</config>
but when I changes it here, nothing happens. Can anybody explain that?
/Kate
It is working now
To make 2 templates I did this:
<config key="entity_encoding">raw', template_templates:[ { title : "Two Column", src : "/home/TwoCol.aspx", description : "Two Column layout" }, { title : "Blockquote", src : "/home/Blockquote.aspx", description : "Blockquote" }], template_popup_height : '400</config>
And to save it after making changes to the tinyMceConfig.config I had to resave the web.config file
tinyMce template plugin
/Kate
It is working now
