  • Shaun 248 posts 475 karma points
    Sep 20, 2010 @ 13:09
    Shaun
    Problem installing blog4umbraco
    I've been having trouble with the blog4umbraco package, so I uninstalled it and attempted a reinstall.
    However, it fails with the following error.
    Could not load file or assembly 'Microsoft.Scripting.ExtensionAttribute, Version=2.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.
     I've checked and there is no microsoft.scripting.extensionatttribute.dll in the bin dir of the site, but neither is there one in my original build folder that I downloaded from the umbraco site. I'm using 4.5.2.
    Should this .dll be installed by the blog installer?
  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    Sep 20, 2010 @ 17:43
    Tim
    That's something to do with the DLR I think. Do you have .Net 4 on your machine?
    Sep 20, 2010 @ 18:01
    Shaun
    It is installed by the host yes, apparently I have 1.1, 2.0, 3.5 and 4.0 on there.
    How best can I resolve the problem? Do I need to get them to switch off 4.0 for my site?
    Sep 20, 2010 @ 18:04
    Tim
    I'm not sure. I think that DLL should be installed as part of the framework install (although I could be wrong). Have you asked your host about it?
    Sep 20, 2010 @ 18:19
    Shaun
    I will do now!
    Thanks for your help Tim
    Sep 21, 2010 @ 13:09
    Shaun
    The hosts confirmed that this dll was part of the framework but I still encountered problems until I copied the dll into the bin directory. it then installed correctly.
