I'm trying to innstall a Hubspot tracking code on our pages, but I can't find how and where to do it. When I click the "HTML" button I don't get the whole source code. Can somebody please help...?
You'd probably want to do this in your Template(s) rather than the WYSIWYG - check Settings -> Templates. Typically there is one Master template that all the child templates inherit from, and you can add the code here.
What I usually do is creating a new property on my homepage-node in Umbraco. The property must be of the type: Textbox multiple. Inside of this textbox the customer/webmaster can copy/paste all the tracking codes that they want.
Then I'll create a XSLT-macro with a small piece of code:
Then I place the macro in my master-template the place where I want the tracking-code(s) to be rendered.
I think it's a good way of doing it, so that if a customer someday needs to insert a new tracking-code, they don't have to change the templates, but just insert the code in the tracking-textbox on the homepage.
Tacking code
Thanks for the tip! Did'nt have access to the template at first, but now I do! :)
Hi Yvette
Just my 5 cents :)
/Kim A
