Hi im trying to use upload Datatype in Doc2Form with PageTabs but the images will not be saved?
Any suggestions how to solf that.
Using Umbraco 4.0.1 and doc2Form 3
Bset regards
I've got this problem at the moment on 4.5.2. Does anyone know what might be causing it.
P
I solved it to let the uploads in a tab taht needs to be the last one then it worked.
Martin
Using upload with PageTabs Doc2Form doesnt work
Bset regards
P
Martin
