  • Connie DeCinko 931 posts 1160 karma points
    Sep 27, 2010 @ 23:49
    Connie DeCinko
    Default Umbraco 404 handler refuses to run
    Last week I had no problem with the default 404 handler "handle404".  Today it apparently has gone AWOL.  I cannot for the life of me get the Umbraco 404 page to display.  In trying to still get a sitewide custom 404 for any type of page work, I removed the 404 from IIS, I'm tried varius settings in Umbraco and web.config and no matter what, all I get is the generic 404 error for .html, .cfm, .aspx, folders or files with no extension, etc.
    404handlers.config
    <NotFoundHandlers>
      <notFound assembly="umbraco" type="SearchForAlias" />
      <notFound assembly="umbraco" type="SearchForTemplate" />
      <notFound assembly="umbraco" type="SearchForProfile" />
      <notFound assembly="InfoCaster.Umbraco._301UrlTracker" type="Handler301URLTracker" />
      <notFound assembly="umbraco" type="handle404" />
    </NotFoundHandlers>
    Sep 28, 2010 @ 00:01
    Connie DeCinko
    NOTE:  Cannot edit forum posts due to XSLT error.
    web.config
      <system.web>
        <customErrors mode="Off" />
      <system.webServer>
        <httpRedirect enabled="false" destination="" exactDestination="true" httpResponseStatus="Permanent" />
        <httpErrors>
        </httpErrors>
      </system.webServer>
  • RuneO 36 posts 116 karma points
    Sep 29, 2010 @ 13:48
    RuneO
    How does your site behaves with the above settings if you doesn't get the standard Umbraco 404 error page catched in handle404?
    Regards,
    Rune
