  • Tom Cowling 144 posts 343 karma points
    Sep 28, 2010 @ 12:29
    Tom Cowling
    Moving folder's contents
    Hi Everyone,
    I need to change a page I've got to use a different document type. I know that to do this I will have to re-create the page. The problem I have though is that it is a parent page has has about 50 child nodes.
    Is there any way to create a new page, then select all the child nodes and move them all at once? It seems like an awful lot of work to right click every node and select move, then browse to the folder.
    Thanks in advance!
    Tom
    Sep 28, 2010 @ 14:46
    Lee Kelleher
    Hi Tom,
    As far as I'm aware, there isn't a bulk document mover. It would need to be a manual process. :-(
    However you should take a look at Matt's Doc Type Extensions package:
    http://our.umbraco.org/projects/developer-tools/doc-type-extensions
    There might be a way of swapping the Master doc-type of the page?
    Good luck.
    Cheers, Lee.
    Sep 28, 2010 @ 14:48
    Tom Cowling
    Nice one - thanks Lee.
