I've just installed a completely fresh version of Umbraco 4.5.2 for .NET 4.0 and i've patched it with the ASP.NET security patch.
Everything is running fine and smooth but there's one single problem that I've come across. When I right click a node and select "Edit in Canvas" I get the following error in a blank window:
"An error occured while processing your request."
Tried searching here on the forums and on Google, but didn't really find a solution for it.
Has anyone had problem with this before? And know of a possible fix? :-)
Completely forgot about this post of mine - sorry about that ;)
Nope, sadly I haven't been able to find a fix for this yet. It would be great to have solved though. I'm not sure I get the "requisite form tag"-thing, can I trick you into elaborating that one? :)
Edit in Canvas error
Hi fellow Umbraco users,
Any help on this will be greatly appreciated!
Thanks in advance,
Bo
Also, i'm sorry if this is the wrong forum to ask this question, feel free to remove/move this thread if it's the wrong forum :)
Did this go away? I got some error, not sure it was the same as yours, but was missing the requisite form tag.
Hi amac44,
All the best,
Bo
