    Oct 01, 2010 @ 11:45
    dandrayne
    How to disable codeMirror (code editor)?
    Hi folks
    Does anyone know how to disable codeMirror from within the umbraco admin?
    I find it very slow on large css files, but the thing that really gets me is changing tab indents to be "2 spaces", which makes the scripts and xslt a bit messy.  I use an external text editor to edit scripts anyway, so would love to know how to get rid of codemirror!
    Anyone have any ideas?
    Dan
    Oct 01, 2010 @ 12:59
    Lee Kelleher
    Hi Dan,
    In umbracoSettings.config... set the "scriptDisableEditor" to true.
    Cheers, Lee.
    Oct 01, 2010 @ 13:33
    dandrayne
    Seems obvious now ^^
    Cheers Lee
    Oct 01, 2010 @ 13:36
    Lee Kelleher
    It's the old "easy once you know how"! ;-)
