  • Ralph 1 post 21 karma points
    Oct 06, 2010 @ 17:06
    Ralph
    A/B Testing
    Does anyone have any tips on how to do A/B testing in Umbraco 4.5? I'd like to show 50% of visitors one look for the homepage, and the other 50% a different look. The homepage would be the only one involved in the test, so the rest of the site can remain the way it is now. Any advice is appreciated.
  • Matt Brailsford 4125 posts 22224 karma points MVP 9x c-trib
    Oct 07, 2010 @ 09:59
    Matt Brailsford
    Hi Ralph,
    Off the top of my head, I would probably think to write a Macro to go on a base Homepage template which, on certain criteria, transfers to an alternative template.
    Alternative templates in Umbraco allow you to append the alias name of a template, onto the end of a Url in one of 2 formats:
    1) homepage.aspx?altTemplater=homepage1
    2) homepage/homepage1.aspx
    What an alt template allows you to do, is render the main Homepage template, using the alt templates master page file, this providing a different layout, but still accessing the same page properties.
    Hope this helps
    Matt
    Oct 07, 2010 @ 10:12
    Dirk De Grave
    Seems like the best way, here's another thread on the same subject.
    /Dirk
  • Ondrej Pialek 7 posts 138 karma points c-trib
    Jul 08, 2015 @ 04:47
    Ondrej Pialek
    This is an old topic but for people who get here via search:
    There is a new plugin called uSplit being developed that bakes A/B testing into Umbraco. It is a commercial plugin but there is a free version available that does redirect-based A/B tests. You can check it out at http://usplit.endzone.io/
    Hope it will help someone struggling with A/B tests :)
