I just got this error.
I installed a new umbraco and then i installed "Gecko Uploadify"
I haven“t created/installed or deletet any thing.
The only thing I did was to upload an images and then this error occurred.
Can anybody help me
It might be the version of .NET that your are running, I had a similar issue on a server that was running the .NET 4.0 version of umbraco 4.5
If you look at the database log it should say something about dll versions not matching
Hope that helps,
-Sean
Maybe it's my .net, but I got it fixed by going under Settings -> Media Types. File and Images, under Generic properties the Type were set to umbracoExtensio. I change it to umbracoExtension och now it works :-)
Can anybody help me
Hope that helps,
-Sean
