I am running Umbraco 4 and I have defined some styles to use within the TinyMCE editor i.e. H1, H2 etc. However, I can't seem to get them to align properly.
If I highlight text and select one of the header options it will align to the left by default, if I then select an alignment option from the toolbar e.g. center, it will align fine in the editor. I checked the HTML at this point and it doesn't appear to have changed (which is odd) so I can't understand why the editor is aligning the header. Anyway, the result is when I then save the page the alignment is discarded and it is moved back to the left.
Does anyone have any idea's why this is happening?
I ended up setting up a local install of umbraco and ran it out of the box.....still got the same problem. After some investigating I noticed that the valid_elements field in the tinyMceConfig.config file was allowing the align attribute, but the actual editor (when you select alignment) applies the style attribute! So I added that into the valid_elements and restarted Umbraco and it worked!
However, I am trying to apply the same changes to my live site and it doesn't seem to be updating? Does umbraco cache configuration files or something like that? I have tried restarting it a good few times now and it still doesn't seem to pick up. Also cleared browser history etc
Header tag alignment working in editor, not saving on page
Any ideas?
Managed to resolve this issue, had to recycle the App Pool
