  • David W. 159 posts 284 karma points c-trib
    Oct 08, 2010 @ 15:26
    David W.
    Custom datatype - key/value dropdownlist
    I'm looking to create a DataType that should work as a key/value dropdownlist, but when I try to create one (using dropdown list as "Render control") I seem to only be allowed to edit the 'Text'. The 'Value' gets an integer automatically assigned.
    I want to use the dropdown so that editors can choose a 'style' for a certain document type. I want the text in the ddl to be Green, Blue and Red, and I would like theit corresponing value to be something like myGreenCssClass, myBlueCssClass etc. This so I can use
    <xsl:value-of select="./data[@alias = 'myCssColorProperty']"/>
    in a xslt macro. Can I achieve this?
  • Mike Chambers 636 posts 1253 karma points c-trib
    Oct 08, 2010 @ 23:44
    Mike Chambers
    Think this is what you are looking for,,,
    http://www.richardsoeteman.net/CommentView,guid,24E1D561-1F6C-4411-BD62-584023D31DF7.aspx#c97c0910-13e7-4d21-88a4-aaae18e44043
    specifically look at the line
     this.Items.Add(new ListItem("Title", "nodeName"));
    eg new ListItem(Text, Value)
    I discovered it linked from http://our.umbraco.org/wiki/how-tos/how-to-create-a-custom-macro-parameter-type
