  • Geoff Baldwin 80 posts 100 karma points
    Oct 14, 2010 @ 12:04
    Geoff Baldwin
    How to display a multiline text box (or simple editor) on separate lines?
    My apologies if this has been answered before but a search didn't reveal anything.
    I have added a property to the site tab of a runway home page for the Company address. I have used both a multiline text box and a simple editor and get the same result.
    On the home page site tab I enter the following into the box:
    Peachy House
    Road Name
    Town
    County
    Post Code
    I then use
    <umbraco:Item runat="server" field="companyAddress" recursive="true" /><br>
    to display the address on a contact page (I have configured the contact page as two columns with Co info on the left and a contact form on the right)
    What I get displayed is:
    Peachy House Road Name Town County
    Post Code
    How do I force each line of the field to appear as a separate line on the diaplayed page please?
    Oct 14, 2010 @ 12:29
    Geoff Baldwin
    OK OK -- stupid boy!!
    Add <br> to the end of each line!
    I just didn't expect that an end user would be expected to add html?
    Is there no way of seting a <br> as the default if a user types CR??
    Oct 21, 2010 @ 14:06
    Geoff Baldwin
    I keep getting robot e-mails asking me if the problem is solved. As I cannot mark it as solved unless someone else posts perhaps some one would post and I'll use it to mark 'solved'!!
    Oct 21, 2010 @ 14:17
    Tom Fulton
    Hi Geoff,
    There's an option in the umbraco:Item tag to convert line breaks to BR's.  When inserting the item it's a checkbox towards the bottom, or just add this attribute:
    <umbraco:Item runat="server" field="companyAddress"  convertLineBreaks="true" recursive="true" /><br>
    Tom
    Oct 21, 2010 @ 14:43
    Geoff Baldwin
    Thanks Tom - problem solved and marked as such!!
