I have a different twist on this problem that I am hoping you can help with.
The umbracosettings.config is set and when I try to hit www.domain.com/somename.aspx I get the correct 404 page. However if I hit www.domain.com/somenamewithnoextension I get the "The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable." message.
Is this an IIS setting when file extensions are missing or incomplete or is this set on the server? Thanks R-
Then I try the feature.
I open /notExistsUrl and /notExistsUrl.aspx: I receive my error404 page.
I open /notExistsUrl.asp and /notExistsUrl.php: I receive IIS standard 404 error page.
I solved this issue adding this in /web.config file.
404 page settings not working
Hi all,
I've updated umbracoSettings.config
<error404>1234</error404>
with the correct page ID but this doesn't seem to work. Have restarted (edit web.config) but still not being picked up. Just get IIS message
Thanks.
Always configure it both in IIS as Umbraco, depending on which of both is handling the error (depends on extension of the mistyped url)
Thanks. I did that (set in IIS7) and it's all working now. Cheers
Hi again,
Problem is back, but in a different form. If I try to visit
mysite.com/somename
I get my lovely custom 404 page. but if I visit
mysite.com/somename.aspx
I get the "this page has been left intentionally ugly" Umbraco page. Any ideas?
for anyone stuck on this, you need to remove poetpatcher info from 404handers.config. See http://our.umbraco.org/forum/templating/templates-and-document-types/13923-Unable-to-get-custom-404-page-to-work
Thanks Paul. The poetpatcher tip helped out a bunch
R-
I would tell to community my personal experience.
I changed
/Config/umbracoSettings.configfile. I set the ID of my page that will be manage Error404.Then I try the feature.
I open
/notExistsUrland/notExistsUrl.aspx: I receive my error404 page.I open
/notExistsUrl.aspand/notExistsUrl.php: I receive IIS standard 404 error page.I solved this issue adding this in
/web.configfile.The web.config changes within this comment worked a treat for me.
Thanks Flavio
