I am trying to setup the following using umbracoRedirect
www.domain.com/folder1/ directing to;
www.domain.com/folder1/page1.aspx
I have added a content picker with the alias umbracoRedirect to the folder1 document type and selected page1 as the content to direct to.
When i run the umbraco site within Visual Studio the redirect works as expected. When i upload my site to the live web server (running IIS6) it shows a page not found.
And what does 'upload my site to the live web server' mean? Did you just copy the database and file system over to the live server? Sure you've published all top level nodes (and optionally performed a republish entire site from the 'Content' node)?
Which version of Umbraco are you running and could it maybe have something to do with permissions? And are you sure that it is not because of a typo? (I've hammered my head against the wall a few times realising my fingers are too big! ;-))
I am running version 4. I am sure it is not a typo because it works on my development machine using Visual Studio. It is when I copy the site to a windows server running IIS that the redirect stops. The rest of the site works perfectly, and if I reference the page directory page using;
www.domain.com/folder1.aspx
the redirect kicks in a directs the user to;
but not if I reference the folder without the extension
I tried adding this property to a documenttype on a 4.5.2 install last week, and the contentpicker just wouldn't load for this property... so i suspect there are some issues somewhere...
umbracoRedirect question
Any suggestions?
Thanks in advance
Hi David
Are you sure that the id you select locally also exists on your live web server?
/Dirk
Thanks both replies. Yes the id I selected does exist, and yes I have peformed a full publish from the content node and still does not work.
Any thoughts?
For developers purposes: Just to say, I am also getting this error on 4.7. Page not found error with debug information below.
David (if you're still listening), and Max,
I think you need to configure your server for extensionless URLs so that /folder1 is handled correctly. There are instructions in the wiki: http://our.umbraco.org/wiki/install-and-setup/setting-up-umbraco-for-friendly-urls (Scroll to the bottom for IIS 7 instructions.)
