<msxsl:script language="c#" implements-prefix="randomTools"> <msxsl:assembly href="../bin/umbraco.dll"/> <![CDATA[ /// <summary> /// Gets a random integer that falls between the specified limits /// </summary> /// <param name="lowerLimit">An integer that defines the lower-boundary of the range</param> /// <param name="upperLimit">An integer that defines the upper-boundary of the range</param> /// <returns>A random integer within the specified range</returns> public static int GetRandom(int lowerLimit,int upperLimit) { Random r = umbraco.library.GetRandom(); int returnedNumber = 0; lock (r) { returnedNumber = r.Next(lowerLimit, upperLimit); } return returnedNumber; } ]]> </msxsl:script>
thumbnails from media folder
I’m stuck :)
I need to create a XSLT which lists 8 random images from a specific media folder.
Here is what i have so far.
-Added a property to my textpage documentType called ThumbnailFolder of type Media Picker. (each page have it's own media folder)
-On the page i select a media folder.
-Created a XSLT file and macro called thumbnailList
The XSLT output should be incorporated in a template.
I use Umbraco 4.5.2 and imageGen
And as i side note: subpages may not have a thumbnail folder so i should look up until it finds the property.
Does i make any sence?
This is what i have so far
<!DOCTYPE xsl:Stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath"
exclude-result-prefixes="msxml umbraco.library Exslt.ExsltMath">
<xsl:template match="/">
<xsl:value-of select="umbraco.library:GetMedia($currentPage/thumbnailFolder, 'True')"/>
<xsl:variable name="imgFolder" select="umbraco.library:GetMedia($currentPage/thumbnailFolder, 'True')"/>
<xsl:value-of select="$imgFolder/umbracoFile"/>
<xsl:param name="imgFolder" select="umbraco.library:GetMedia($currentPage/thumbnailFolder, 'True')" />
<xsl:value-of select="$imgFolder"/>
<xsl:if test="$imgFolder!=''">
<xsl:for-each select="umbraco.library:GetMedia($imgFolder, 'true')/descendant-or-self::*[@nodeTypeAlias='Image']/umbracoFile">
<img>
<xsl:attribute name="src"><xsl:value-of select="." /></xsl:attribute>
<xsl:attribute name="alt"><xsl:value-of select="../@nodeName" /></xsl:attribute>
</img>
</xsl:for-each>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
This line: <xsl:value-of select="$imgFolder/umbracoFile"/>
shows me all the images but the for-each loop results in an parsing error
Hi Michael
I think you can use something like this:
I haven't tried the above code, but I think it will work.
/Kim A
Thanks Kim!
got it working besides the random bit!
Here is the code so far
<xsl:stylesheet
version="1.0"
<xsl:param name="imgFolder" select="$currentPage/thumbnailFolder" />
<xsl:if test="position() <= 8">
<a href="">
<img>
<xsl:text>/umbraco/ImageGen.ashx?image=</xsl:text>
<xsl:value-of select="."/>
<xsl:text>&width=40</xsl:text>
<xsl:text>&height=40</xsl:text>
</xsl:attribute>
</img>
</a>
</xsl:if>
</xsl:for-each>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
Hi Michael
On the random part I Think you Can benefit from this entry http://our.umbraco.org/wiki/reference/xslt/snippets/getting-a-series-of-unique-random-numbers
Have tried several times the last days, but no luck with the random images :-/
Can anyone help please!
Here is the code so far:
<xsl:stylesheet
version="1.0"
<xsl:for-each select="umbraco.library:GetMedia($imgFolder, 'false')/Image">
<a rel="lightbox">
<xsl:attribute name="href">
<xsl:value-of select="umbracoFile"/>
<xsl:text>&width=640</xsl:text>
</xsl:attribute>
<xsl:attribute name="title">
<xsl:value-of select="@nodeName" />
</xsl:attribute>
<img>
<xsl:value-of select="umbracoFile" />
</xsl:attribute>
</img>
</a>
</xsl:if>
</xsl:for-each>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
Hi Michael
Have you had a look at the link I posted previously?
Obviously you are'nt using it in the posted code above. Try having a look at it. It works like a charm once it's implemented.
You were right :) gave it one more try and i works perfectly :)
Thank you for the help!!
If anyone else need an example of how to random select x pictures from the media library then here is my result:
<xsl:stylesheet
version="1.0"
xmlns:msxsl="urn:schemas-microsoft-com:xslt"
xmlns:randomTools="http://www.umbraco.org/randomTools"
exclude-result-prefixes="msxml umbraco.library msxsl randomTools">
<xsl:variable name="maxItems" select="number(8)" />
<xsl:sort select="randomTools:GetRandom(0,count(umbraco.library:GetMedia($imgFolder, 'false')/Image))" order="ascending" />
<xsl:if test="position() <= $maxItems">
<a rel="lightbox">
</xsl:attribute>
</xsl:attribute>
<img>
</xsl:attribute>
</img>
</a>
</xsl:if>
</xsl:for-each>
</xsl:if>
</xsl:template>
<![CDATA[
/// <summary>
/// </summary>
lock (r)
</msxsl:script>
</xsl:stylesheet>
