I'm trying to find a way of displaying a list of nodes on every page of my site. The nodes I want to display sit under a specific node. Is there a way I can show every node under the specified node ID?
Thanks for any help.
Yes,
if you're using the nodefactory you can query a certain node for its children, and iterate over them, a quick example:
Node _node = new Node(id);foreach (Node _n in _node.Children) {
// do stuff
For 4.5
<!--Loop children from certain node--> <xsl:for-each select="umbraco.library:GetXmlNodeById('18616')/* [@isDoc][string(umbracoNaviHide) != '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a> </li> </xsl:for-each>
Prior to 4.5
<!--Loop children from certain nodeà<xsl:for-each select="umbraco.library:GetXmlNodeById('18616')/node [string(data[@alias='umbracoNaviHide']) != '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a></li></xsl:for-each>
<li>
</li>
</xsl:for-each>
You will need to update the node id to the one you need.
Rich
Display list of nodes on every page of site?
Yes,
// do stuff
For 4.5
Prior to 4.5
Rich
