  • Kevon K. Hayes 255 posts 281 karma points
    Oct 21, 2010 @ 20:32
    Kevon K. Hayes
    UMB 4.5.2 Color Picker doesn't display colors
    I created a datatype "MyColors" from the "Approved Color" datatype, assigned some hex color values to it (prevalues) e.g. FFFFFF, 000000 and saved it.  I created a property of type "MyColors" and saved and I just get the following  just wondering what may be the issue here?
  • Claushingebjerg 939 posts 2574 karma points
    Oct 22, 2010 @ 13:17
    Claushingebjerg
    Have you installed Gecko Uploadify?
    I have experienced the same thing, but havent had the chance to test it on a site without gecko uploadify. What i discovered is, that gecko creates a root folder on the site called "~" and since umbraco looks in ~/umbraco/images for the grapic spacing out the colors on the color picker it suddenly cant find the image... hence the collpased divs with no colors.
    Oct 22, 2010 @ 19:37
    Kevon K. Hayes
    No, are you saying to utilize an OOB Umbraco Datatype I must install a community package?
    Oct 22, 2010 @ 19:49
    Tom Fulton
    It looks like a bug as far as I can tell
    As Claushingebjerg mentioned, it's filling the div with an empty img via ~/umbraco/images/nada.gif - but Fiddler reports it actually looking for /umbraco/~/umbraco/images/nada.gif which results in a 404.  I guess it's not handling the ~ properly
    Oct 22, 2010 @ 20:04
    I just checked on a clean Umbraco 4.5.2 install and it acts the same way. Definately a bug.
    Oct 22, 2010 @ 20:07
    And it's already been reported in this issue on codeplex. Vote for it here: http://umbraco.codeplex.com/workitem/28810
    Oct 22, 2010 @ 20:18
    Kevon K. Hayes
    My discovery was on a clean install as well so thanks guys
    Oct 23, 2010 @ 08:59
    Claushingebjerg
    @Kevon, no what i meant was i have only used the color picker on sites where i had already installed gecko... And gecko has a bug which actually creates the ~directory...
    as a workaround i actually made a copy of /umbraco/images and copied it to the ~ directory. And  hey presto, it works. Im sure its not the right way to go, but it solves this problem...
