I have created a custom control that works perfectly in the IDE on my local machine, however when I put it into Umbraco, the Ajax controls are not working correctly.
I am using validator extenders. I have followed the instructions about installing the ajaxcontroltoolkit35.dll. Please could someone take a look and see if there is something obvious that I have missed? The control in question is the contact form which can be viewed and tested at:
What seems to be happening, is that the validators are working correctly, as if the extenders do not exist. The validation does seem to work in real time after the first postback, which makes me think that some ajax functionality is working, just not as expected. I have tried using the IE developer toolbar to see if there are any javascript errors, but nothing seems apparent.
I'm not that up on the Ajax Control toolkit, but from taking a quick look at the page, it's throwing a javascript error saying that AjaxControlToolkit35 is undefined, are you missing some javascript files somewhere?
Thanks for that. How did you get a javascript error. I have been trying really hard to get some feedback from the browser, and it's not forthcoming. I have the ajaxcontroltoolkit35.dll file in the bin folder. I assume that is enough. Does anyone know any different?
I am going to remove it from the bin folder to see what happens.
I removed the ajaxcontroltoolkit35.dll from the bin folder and the control refused to load. Only a red rectangle appeared in it's place with an error message in it.
Hi, i've used ajaxcontroltoolkit (concrectly ver. 3.5) in some usercontrols, and i made use of the same ajaxcontroltoolkit.dll that is on the vs bin folder to deploy it to umbraco, so maybe it's possible for you use the same .dll in both sides, (that maybe is what is giving errors)
I have attached the ajaxcontroltoolkit35.dll to vs, and have the same file deployed to the server. Should I be using a different verion of the file on the server than the one on the local machine?
No, sorry, I thought that you used different version for the ajaxcontroltoolkit.dll, because there is one personalized version for umbraco, and that this could be the problem.
I just loaded the link up in IE8. I get the little javascript exclamation mark in the bottom left of the window, and clicked on that to get the error message. It's something you usually get when there's a javascript file or something missing. I'm afraid I can't offer much help on how to work it out for the AjaxToolkit, as I don't have that much experience in using it!
I'd check the site you have where it works properly and see if there are any .js files that appear to be associated with the toolkit.
All of these undefined items are in the generated page, but the first error is the most telling. I have asked my web hosting company to take a look and see if there is some misconfiguration on the server. If anyone has seen this before and knows what's going on, please let me know.
I have checked the installation of the AjaxControlToolkit35 and its references within the program and they are fine. The form at the other link is identical just running on a page by itself and poses no problems.
Can anyoen offer any suggestion on where to look next?
Ajax control problems
http://velosiweb.es4i.com/about-us/contact.aspx
Umbraco version is: 4.5.2 for .net 4
asp.net ver 4
windows server 2008 with iis7
No stacktrace available.
Regards
John
Hiya,
Tim.
Hi Tim
Regards
John
Hi Tim
Regards
John
Regards.
Hi Kerio
I don't quite understand.
Regards
John
regards
Thanks Tim. A quick update on this:
I installed the web application containing the user control into a separate domain, and it gives me the following errors:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; GTB6.6; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E; InfoPath.3; eMusic DLM/4; AskTB5.6; Creative AutoUpdate v1.40.02)
Timestamp: Thu, 11 Nov 2010 12:13:11 UTC
Message: ASP.NET Ajax client-side framework failed to load.
Line: 42
Char: 34
Code: 0
URI: http://www.raystorm.co.uk/music/
Message: 'Sys' is undefined
Line: 50
Char: 1
Code: 0
Message: 'Type' is undefined
Line: 2
Char: 1
Code: 0
URI: http://www.raystorm.co.uk/music/Default.aspx?_TSM_HiddenField_=ctl00_MainContent_ContactFormControl1_ToolkitScriptManager1_HiddenField&_TSM_CombinedScripts_=%3b%3bAjaxControlToolkit35%2c+Version%3d3.0.30512.22510%2c+Culture%3dneutral%2c+PublicKeyToken%3d28f01b0e84b6d53e%3aen-US%3a34d65f0c-7447-4d7d-bde9-ac22a7335970%3ac0c9b886%3a72717c12%3a9ce76ec2%3a7ed0955d%3a9dc6f995%3a94eafb88%3aeb6fa8d3
Line: 234
Char: 1
Code: 0
Line: 362
Char: 1
Code: 0
Regards
John
The guys at the ISP did something (not sure what and they claim that they didn't) but now the custom control works fine in it's own website here:
It still refuses to work in the Unbraco environment. The only error is this:
Timestamp: Wed, 17 Nov 2010 11:26:04 UTC
Message: 'AjaxControlToolkit35' is undefined
Line: 579
Char: 5
Code: 0
URI: http://velosiweb.es4i.com/about-us/contact.aspx
Regards
John
I solved the problem by changing the ScriptManager in the template hosts control macro
first add the reference
<%@ Register assembly="AjaxControlToolkit" namespace="AjaxControlToolkit" tagprefix="ajaxToolkit" %>
and then remove the scriptmanager and add this
<ajaxToolkit:ToolkitScriptManager ID="ToolkitScriptManager1" runat="server"></ajaxToolkit:ToolkitScriptManager>
