i keep getting this error when i try saving a member.
i dont have any special dataypes or anything, just standard textstrings.
Hi Phil,
Try reinitializing IIS, publish the entire site to refresh cahe.
Refresh the members node.
Hope this helps.
Sincere regards,Eduardo Macho
I'm getting the same error when saving a member, did you manage to find a solution?
Cheers
Aron
yes i had a property called 'email' which was conflicting with the email property umbraco has by default.
That's fixed it. I had the exact same issue.
Cheers, i owe you a beer.
saving member throws exception
An item with the same key has already been added.
Hi Phil,
Hope this helps.
Sincere regards,
Eduardo Macho
Cheers
Aron
Aron
