  • Robert 13 posts 33 karma points
    Nov 11, 2010 @ 17:03
    Robert
    Template Folder Won't Open in UI
    My Template Folder has stopped working--it will not open.  In Settings, everything else works. The folders open and the files are accessible. Everything but Templates.  All of the templates do exist in the masterpages folder, I just can't get to them anymore from the UI.
    If I try to create a new template, I do get the dialog that asks for the new name. I enter a name and click create.
    Then, I get what is one of our custom error pages. It is custom 404 error page sitting inside of the Create dialog box.
    Any ideas are much appreciated!  Thanks!
    Version: umbraco v 4.0.4.2 (Assembly version: 1.0.3811.17115)
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Nov 11, 2010 @ 17:22
    Richard Soeteman
    Hi I think you need to check, double and triple check the Security settings on that folder, Make sure the user NetworkService had modify rights on that folder.
    Richard
    Nov 11, 2010 @ 17:36
    Robert
    Thanks, Richard.
    I have checked Security several times. The permissions are exactly the same as those enabled for a folder that works (like css) including Network Service.
    But, it still does not work.
    Nov 12, 2010 @ 00:39
    Robert
    UPDATE: I did notice that the Document Types folder will open but the files listed there just show the same custom 404 page in the main window.
