  • Raxit 26 posts 46 karma points
    Nov 15, 2010 @ 15:48
    Raxit
    Async File upload control of Ajaxcontroltoolkit with Umbraco
    We are trying to use async file upload control with latest version of ajax control toolkit in umbraco but unable to get to work properly. Are there any known issue anyone aware of?
    Once we try to upload any file, no events gets fired on the user cotnrol where it is placed.
    Umbraco version : 4.5.2
    IIS : 7
  • Chris Koiak 700 posts 2626 karma points
    Nov 15, 2010 @ 15:51
    Chris Koiak
    Are you trying to use it in the front end or back end?
    Nov 15, 2010 @ 15:57
    Raxit
    In frontend public facing site. We created a macro out of a user control which uses async file upload.
    Nov 15, 2010 @ 15:59
    Chris Koiak
    There should be no issues using any controls on the front end of Umbraco. Try getting the code running on normal aspx pages first and then move it across to Umbraco.
    Nov 15, 2010 @ 16:42
    Raxit
    Yes we did the same and it is working without any issues the moment we moved into umbraco its not working as expected.
  • Ilya 18 posts 53 karma points
    Feb 27, 2013 @ 21:36
    Ilya
    Raxit, have you found a solution? I've just met the same problem today: no events are firing when trying to use Async File upload in Umbraco usercontrol.
    Have no idea what is the problem's root. Hope you've found an answer :)
