  • Manos Gatsios 21 posts 41 karma points
    Nov 15, 2010 @ 16:16
    Manos Gatsios
    Rich text editor issue!
    Hi all,
    Any idea why the rich text editor (tinymce) will add extra line breaks (br) at the end of each line after upgrading from 4.0.3 to 4.5.2 ?
    Any suggestions will be really appreciated...
    Manos
  • Brendan Rice 538 posts 1102 karma points
    Nov 17, 2010 @ 15:26
    Brendan Rice
    There is a config file that comes with the TinyMCE editor in Umbraco config/TinyMCE.config  you might find a setting in there that would help you.
    Here is a wiki with all the TinyMCE settings in it:
    http://wiki.moxiecode.com/index.php/TinyMCE:Configuration
    Nov 17, 2010 @ 15:48
    Manos Gatsios
    Hi Brendan,
    Thanks for this, I was already digging into that file.
    I guess I should be looking at the "force_br_newlines" setting which is probably equivalent to setting the property convertLineBreaks in a field item.
    But I am still puzzled because the same code never produced those extra BRs when was running under the 4.0.3 version.
    The only explanation I can think of is that the default tinyMCE settings have been altered in the new version.
    Anyway thanks again for your reply.
    Nov 17, 2010 @ 16:03
    Brendan Rice
    No worries hope it helps.
