As you all know you'll find the dictionary items under the Settings section. This is not great cause often only the developer has access to this section. So, before I start to do a package or something it would be nice with some input from the community!
Is there a solution/package for export/import?
Can I allow acces only to the dictionary part and not the whole Settings section?
I can't say I've tested this, but you should be able to move the dictionary app tree to another section by modifying the appAlias column in the umbracoAppTree table. If like most setups though, your client only has access to content / media, you may want to look at creating a custom section, and moving it over to that section and just enabling acceess to that section aswell.
You can find an example of creating a custom section here:
What Matt said. I think you can just copy the row for the Dictionary tree and add that to a custom section too, so that it's still in the developer section as well as the custom section.
Dictionary Items
Hello all
Thanks!
Hey Kenneth,
http://www.geckonewmedia.com/blog/2009/8/3/how-to-create-a-custom-section-in-umbraco-4
Matt
I've created a package which will create a section in which you can only edit dictionary items: Digibiz Dictionary Section.
Jeroen
