This might be a dumb question, but I'm new to Umbraco... anyway I've created a new page type but there's no umbracoNaviHide property (or any other property).
What do I do to add it in? Do I have to add it it manually?
I thought there would be general properties that are on all the pages, prefixed with "umbraco"?
The umbracoNaviHide Property isn't there...
Hi there.
Thanks in advance!
-Evan
Evan,
You need to create them in the past i have used the excellent package http://our.umbraco.org/projects/developer-tools/master-doctype-template
Regards
Ismail
Thanks Ismail. That's what I'm after.
I found a UDT file, but couldn't import it. It might be for the old Schema or something... do you think? Do you know of anything that works with 4.5?
Evan,
That should work with 452 do you get error?
Regards
Isamil
