I this time did a clean install of the files, then copyed back the costum files css, masterpages usercontrols, etc, but still the old icons? - Are the path to those files written in the DB somewhere?
And when clicking on one of the icons I keep getting the Contents page.
If I manually type #settings after the umbraco.aspx in the URL, I get to the page I want, but if I then expands anything in the tree, I'm sent back to the contents section. Then I can type #settings againg, and because umbraco now remebers last opend tree node, I can select what I want to select and edit the page, but if I then need to expand further, I get back to content.
Just looked through the DB and found where the reference was.
If other have the problem then it's the table umbracoApp where appIcon e.g. should be ".traycontent" for content instead of content.gif then it all works.
Backend "Sections" menu and icons wrong
I have just upgraded my 4.0.2 to 4.5.2.
The icon's of the Sections menu are still the old ones see: http://4tw.dk/billeder/umbraco4.png
No one?
I still have this problem. What can I do?
Best regards
Lars
Lars
