  • Scott Seto 2 posts 22 karma points
    Nov 27, 2010 @ 19:36
    Scott Seto
    The first node in umbraco.config changes erroneously when publishing home page
    Hi, I am using Umbraco 4.5.2 and am on a shared server with IIS 7.0.
    When I save and publish my home page after editing it, for some reason, the home page
    changes. It doesn't show up at 'mysite.org' like it should.
     Instead, it shows some other page. I looked into umbraco.config
    and a different node was at the top, right below '<root id="-1">'
    I can fix it by going into the umbraco.config file and moving the node that contains the home page and
    putting it back at the top, but I don't believe I should have to do that every time I edit my home page. I'd like any
    ideas about how I can stop this from happening. Thanks.
    Nov 27, 2010 @ 19:57
    Scott Seto
    nm,
    I figured out the problem.
    There were duplicate nodes in umbraco.config. One copy was named <node...
    and the other was named <insertnameofnodehere...
    I deleted the duplicates and republished.
