  • mans 4 posts 24 karma points
    Nov 30, 2010 @ 19:44
    mans
    How to delete a commenet in weblog?
    How can I delete a commenet in weblog?
    Is there any free user guide for Umbraco?
    Regards
    Nov 30, 2010 @ 22:08
    Hi Mans
    Here you can find a user guide to umbraco: http://our.umbraco.org/projects/website-utilities/editors-manual
    I Asume that you have installed the blog package for Umbraco?
    To delete a comment you will just need to log in to umbraco and find the relevant post and then delete the comment, which I think is placed beneath the post. You do this by right clicking on the comment and choose "delete".
    Hope this helps you.
    Dec 02, 2010 @ 12:37
    mans
    Thanks for your reply. But I still cannot do this :(
    I think I am missing something here.
    I installed the Umbraco and then weblog for it.
    I can log to Umbraco as admin and it show me the backend which I can add content and users and ..., but when I open the weblog, there is no information about comments to for it.
    If I go to the weblog directly,  http://mycom.com/2010/11/30/this-is-a-test-.aspx
    There is no option to delete it.
    Where should I delete it?
    Regards
    Dec 02, 2010 @ 12:52
    Rich Green
    Hi mans,
    You delete it from the umbraco admin system, not from the front end.
    So you would need to go to http:// mycom.com/umbraco/umbraco.aspx , login find the node and do as Jan suggested.
    Rich
    Dec 02, 2010 @ 13:05
    mans
    Thanks for quick reply
    I am going there but there is no node for comments there. I believe that the comments should be under the weblog entry node, but there is nothing under a web log entry.
    Should I enable it in anyway?
    Regards
