  • Fidel 2 posts 22 karma points
    Dec 01, 2010 @ 04:43
    Fidel
    Preview button not working
    When I try to preview my updates only contents that is been made live is displayed.  What the point of a preview function in this case?
    Umbraco 4.1 on windows IE8
  • Barry Fogarty 493 posts 1129 karma points
    Dec 01, 2010 @ 04:51
    Barry Fogarty
    Hi Fidel
    Are you hitting the Save button before preview?  Save just stores the updates in the system, it does not publish the to the live site (Save and Publish does that)
    If you are hitting Save, it could be data processed by XSLT macros - here is a discussion about that:
    http://our.umbraco.org/forum/using/ui-questions/7856-Can%27t-preview-content
  • Aaron Powell 1708 posts 3046 karma points c-trib
    Dec 01, 2010 @ 05:36
    Aaron Powell
    There is no Umbraco 4.1, or there were only preview and beta releases for 4.1
    You should upgrade to 4.5.2 so you're working with something official
    Dec 01, 2010 @ 12:03
    Fidel
    Ooops.. saving before preview works tx
    Salce I will upgrade soon thank you
