  • Touhid 97 posts 117 karma points
    Dec 01, 2010 @ 12:08
    Touhid
    problem with image in a page
    hi,
    In a content a page there are three image upload . and i upload first two image and last is not.
     now my problem is the third image icon is shown which i cant want. how can i solve this problem??
    pls any one help me?
    touhid
  • Barry Fogarty 493 posts 1129 karma points
    Dec 01, 2010 @ 12:35
    Barry Fogarty
    Hi touhid,
    You will probably need to use a macro to check if an image has been selected. Check this post for an example:
    http://our.umbraco.org/forum/developers/xslt/5527-Macro-to-show-an-image-from-Media
    If you post your template/macro code that you are using to render the image we will be able to help further
    Dec 01, 2010 @ 12:46
    Touhid
    thanks for quick reply. now i m  doing that..
    Dec 02, 2010 @ 06:07
    Touhid
    Sory,its late. by the by i could not it successfully. my xslt file and template where i used macro are as follows-( i used a upload data type)
    now what  can i do?
    xslt:-
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
            version="1.0"
    <xsl:variable name="mediaId" select="/macro/mediaId"/>
    <xsl:template match="/">
            <xsl:if test="$mediaId &gt; 0">
                    <xsl:variable name="image" select="umbraco.library:GetMedia($mediaId,'true')"/>
                    <img src="{$image/data[@alias='umbracoFile']}" alt="{$image/@nodeName}">
                            <xsl:if test="/macro/style != ''">
                                    <xsl:attribute name="style"><xsl:value-of select="/macro/style"/></xsl:attribute>
                            </xsl:if>
                    </img>
            </xsl:if>
    </xsl:template>
    </xsl:stylesheet>
    Template:-
    <%@ Master Language="C#" MasterPageFile="~/masterpages/Master.master" AutoEventWireup="true" %>
    <asp:content ContentPlaceHolderId="MainContent" runat="server">
     <umbraco:Item field="header" runat="server"></umbraco:Item>
    <umbraco:Macro Alias="Breadcrumb" runat="server"></umbraco:Macro>
    <umbraco:Item field="text" runat="server"></umbraco:Item>
    <umbraco:Macro mediaId="-90" style="" Alias="Specialties" runat="server"></umbraco:Macro>
    <script language="JavaScript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script>
    <script language="JavaScript" src="/scripts/s3Slider.js"></script>
    <script language="JavaScript">
        $(document).ready(function() {
            $('#slider').s3Slider({
                timeOut: 3000
    </script>
     <div id="slider">
            <ul id="sliderContent">
                <li class="sliderImage">
                   <img src='<umbraco:Item field="photo" runat="server"></umbraco:Item>' height="128" width="128" alt="Photo taken by TOUHID"/>
            <span class="top"><strong>Title text 1</strong><br /></span>
                </li>
                  <img src='<umbraco:Item field="photo1" runat="server"></umbraco:Item>' height="128" width="128" alt="Photo taken by T "/>
            <span class="top"><strong>Title text 2</strong><br /></span>
                </li>
                  <img src='<umbraco:Item field="photo2" runat="server"></umbraco:Item>' height="128" width="128" alt="Photo taken by T "/>
                </li>
                  <img src='<umbraco:Item field="photo3" runat="server"></umbraco:Item>' height="128" width="128" alt="Photo taken by T "/>
                </li>
                   <img src='<umbraco:Item field="photo4" runat="server"></umbraco:Item>' height="128" width="128" alt="Photo taken by T "/>
              </li>
                  <img src='<umbraco:Item field="photo5" runat="server"></umbraco:Item>' height="128" width="128" alt="Photo taken by T "/>
                </li>
      <div class="clear sliderImage">
            </ul>
    </asp:Content>
