  • Patrik Wibron 40 posts 67 karma points
    Dec 06, 2010 @ 11:31
    Patrik Wibron
    Can't edit permissions on a protected page
    Hi!
    I tried to remove the user on a password-protected page and this message hits me: "Access to the path 'D:\Data\customer\data\access.xml' is denied.". We've set full read/modify permissions for the ApplicationPool-user and Network Service on every folder.
    If I try to republish the node or tries to edit the permissions, umbraco is throwing out this:
    Object reference not set to an instance of an object
       umbraco.cms.businesslogic.web.Access.IsProtectedByMembershipRole(Int32 documentId, String role) +119
       umbraco.presentation.umbraco.dialogs.protectPage.Page_Load(Object sender, EventArgs e) +1413
       System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +24
       System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +41
       System.Web.UI.Control.OnLoad(EventArgs e) +131
       umbraco.BasePages.BasePage.OnLoad(EventArgs e) +20
       System.Web.UI.Control.LoadRecursive() +65
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2427
    Any clues what's causing this?
    Setup: Umbraco 4.0.1, ASP.NET 3.5 on IIS7 (Windows Server 2008). SQL 2008.
    / Patrik
  • Tim 1193 posts 2675 karma points MVP 4x c-trib
    Dec 06, 2010 @ 16:22
    Tim
    Something else may be locking the file. Is this on a live server or your local machine? If you have access to the machine this is running on (it sounds like you do). You could try running the tool on this link to see if the file is being locked by something: http://psst0101.wordpress.com/2007/06/19/windows-tip-determining-file-locks/
    Dec 09, 2010 @ 10:02
    Patrik Wibron
    Tried restarting the application and now it works.
