Anybody got a problem with Umbraco refusing to save new user settings?
I get a "Passwords du not mach", and only the firs field is filled.
Guess this is a browser problem, but if I don't fill out the password, doesn't Umbraco change it to [blank]?
Hi Thomas;
If you just want to change user settings, but not the password, you can just leave all password related fields blanks. Your password will then remain unchanged after the save.
Michael.
Thanks a 1.000.000!
Change settings for users gives password problem
Hi Thomas;
Michael.
Thanks a 1.000.000!
