Do you get some kind of error when using the package? Have you followed all the neccesary steps and what version of Umbraco are you using?
Otherwise I think it should be possible to generate PDF files using ASP.NET - Try having a look at this blogpost by Tim Geyssens here: http://www.nibble.be/?p=72
Hi, did you mean that you need a pdf converter? im a office worker, i can recommend you this pdf converter sdk package which can convert pdf to word, html, image and text. I ususlly use such assistant for my large office work.
pdf conversion
hi,
i know there are package for pdf conversion. and i download and install XSL_PDF 1.1 , but it doesnt work.
i need to a content page is download as pdf format. is it possible ???
note: i m using asp.net 3.5.
touhid
Thnks for reply. No, there is no error when using xsl_pdf1.1 package. it just show the node name in a pdf file. now im using umbraco 4.5.2 version.
Touhid
XSL PDF creator for Umbraco 1.1 is built against .net 4.
If you require a 3.5 build then please request it in the project forums (the project has its own forum).
Thanks.
We recently added some customization to an Umbraco projec that we are developing. We needed to convert some pdf files to images.
We decided to use GhostScript and write custom .NET user controls. Here's a link to where we got the idea:
http://www.codeproject.com/KB/cs/GhostScriptUseWithCSharp.aspx
You could also try iTextSharp: http://sourceforge.net/projects/itextsharp/
Or a commercial product like abcPDF.NET: http://www.websupergoo.com/abcpdf-1.htm
Hope that helps.
Daniel Burge
Burada, Inc.
http://www.buradainc.com
HI Daniel
Thnks for reply. Now im great problem in pdf conversion.
I have download iTextsharp. Then waht can io do? Pls help me .
Touhid
Hi Touhid,
Well, after that point you have to learn it and figure it how to use it to fit your needs!
Daniel Burge
Burada, Inc.
well, try to use some PDF conversion tools to convert pdf files to other formats easily. pdf to digital magazine
