  • Chris 69 posts 75 karma points
    Dec 25, 2010 @ 07:29
    Chris
    Google and extension-less urls
    When developing new Umbraco sites, I always use directory urls (without the aspx extension).
    However, I just discovered that in some cases the .aspx pages are indexed by google instead of the extension-less equivalent. Is there any way to prevent this?
    Also when I browse to a specific page, for example www.mydomain.com/about, i notice that it is also accessible through www.mydomain.com/about.aspx. If possible I would like to have only the extension-less url available (with the .aspx page doing a 301 redirect).
    Does anyone have some guidelines about this?
    Thanks a lot!
    Chris
    Dec 25, 2010 @ 11:08
    Lee Kelleher
    Hi Chris,
    You can handle this in IIS7 (using a custom rewrite rule), or using a rule in the UrlRewriting.config.
    I don't have an example to hand right now... but can find one later if you need?
    Cheers, Lee.
    Dec 27, 2010 @ 08:25
    Chris
    Hi Lee,
    Thanks for your reply! I suppose something like the following would do the trick?
    <rule name="RemoveExtension" enabled="true" stopProcessing="true">
    <match url="(.*)\.(aspx)$" />
      <action type="Redirect" url="{R:1}" />
    </rule>
    Or is this not a 301 redirect?
    Does google also see http://www.mydomain.com/about (without ending slash) and http://www.mydomain.com/about/ (with ending slash) as different urls or not?
    Chris
  • Matt Brailsford 4125 posts 22223 karma points MVP 9x c-trib
    Dec 27, 2010 @ 10:34
    Matt Brailsford
    Hey Chris,
    You could also try using the Cononcial meta tag package which adds a canonical meta tag to all your pages, and tells google which version should actually be indexed.
    http://our.umbraco.org/projects/developer-tools/canonical-meta-link-package
    Matt
  • Ove Andersen 435 posts 1541 karma points c-trib
    Dec 27, 2010 @ 11:04
    Ove Andersen
    Google indexes http://www.mydomain.com/about (without ending slash) and http://www.mydomain.com/about/ as two different web pages
    According to http://www.alistapart.com/articles/slashforward/ you should always append a trailing slash.
    Here is a rewrite rule for that:
                    <rule name="Remove ASPX Extension" enabled="true" stopProcessing="true">
                        <match url="^(?!umbraco/)(.+)\.(aspx)$" />
                        <action type="Redirect" url="{R:1}/" redirectType="Permanent" />
                    </rule>
                    <rule name="Add trailing slash" enabled="true" stopProcessing="true">
                        <match url="(.*[^/])$" />
                        <conditions logicalGrouping="MatchAll" trackAllCaptures="false">
                            <add input="{REQUEST_FILENAME}" matchType="IsFile" negate="true" />
                            <add input="{REQUEST_FILENAME}" matchType="IsDirectory" negate="true" />
                        </conditions>
                    </rule>
    Note: I have changed the RemoveExtension slightly to not touch anything in the /umbraco/ folder, as it messes stuff up in the backend.
    Dec 28, 2010 @ 10:36
    Chris
    Thanks for these great insights, guys!
    Good to learn about the canonical link package, Matt. Very nice for doing some extra SEO optimization! I will certainly use this in the future. Do all search engines support the canonical tag already?
    For now, I'll just stick with the good old redirect rules that Ove shared here. These probably spared me a serious regex headache...! ;-)
    Dec 31, 2010 @ 08:35
    Chris
    Hi, just as a reference: The redirect rules work great, but i had to make one small adjustment in order to keep my rest extensions working. This is exluding the /base path from the redirect rule. See code below.
    <match url="^(?!umbraco/)(?!base/)(.+)\.(aspx)$" />
    </rule>
    Thanks again for the great help!
    Chris
