  • Touhid 97 posts 117 karma points
    Dec 29, 2010 @ 08:16
    Touhid
    how to get node id using xslt
    HI
    How can i get current content node id using template or xslt.
    Touhid
    Dec 29, 2010 @ 09:14
    Ismail Mayat
    3
    In the template you can do
    <umbraco:Item field="pageID" runat="server"></umbraco:Item>
    in xslt you can do
    <xsl:value-of select="$currentPage/@id"/>
    I would recommend you download and install the creative website starter kit and look at some of the xslts in there to get to
    grip with Umbraco basics.
    Regards
    Ismail
