    Jan 02, 2011 @ 12:17
    Anthony Candaele
    unable to debug
    I try to debug a usercontrol (SidebarWidget.ascx).
    On my homepage template I have added a macro like this:
    <umbraco:Macro Alias="sidebarWidgets" Widgets="[$sidebarWidgets]" runat="server"></umbraco:Macro>
    For some reasons, the widgets are not showing on my homepage, so now I try to debug the SidebarWidget usercontrol.
    For this I follow the instructions of Niels Hartvig in the video tutorial on debugging (Umbraco TV).
    I set a breakpoint in my SidebarWidget.ascx.cs file and in Visual Studio 2010 I attached the process w3wp.exe
    But if I refresh my homepage, notting happings, Visual Studio does not step into the breakpoint that I set in SidebarWidget.ascx.cs
    Am I overlooking something. The operating system on my development machine is Windows 7 and I use IIS 7
    Thanks for your help,
    Anthony Candaele
    Belgium
  • Comment author was deleted
    Jan 02, 2011 @ 12:52
    @Anthony, and is the macro alias correct ? + if you check the macro is it linked to the correct usercontrol?
    Jan 02, 2011 @ 13:37
    Anthony Candaele
    Hi Tim,
    First of all Happy New Year and lots of success on the Umbraco Team.
    I try to implement the widget solution as instructed by Hendy Racher:
    http://blog.hendyracher.co.uk/sidebar-widgets-with-umbraco-v4/
    One thing, I think I have overlooked, is that I didn't add a macro (SidebarWidget) in the RichText property of my Widget document type:
    But the sidebarWidget usercontrol is not listed in the list of macro's I can add.
    Anthony
    Jan 02, 2011 @ 13:40
    Anthony Candaele
    Hi Tim,
    Anthony
    Kim Andersen
    Hi Antohny, You have to mark the macro as usable in the richtext editor. You can do this in the developer section, find the macro under the "Macros"-folder, and then check the "Use in editor" checkbox.
    /Kim A
    Jan 02, 2011 @ 13:49
    Anthony Candaele
    Hi Kim,
    Yes, I found that out a couple of minutes myself. Now I able to add the macro sidebarWidget to my RichtText property of my widget document type, but still now widget on the rendered page :(
    The problem is that I can't see what's going in my SidebarWidgets.ascx user control because I'm not able to debug that user control.
    Anthony Candaele
    Belgium
    Jan 02, 2011 @ 13:52
    Anthony Candaele
    Hi Kim,
    Anthony Candaele
    Belgium
    Jan 02, 2011 @ 13:57
    Sebastiaan Janssen
    Can you debug it when you just put it as a macro in the template? Might be something else going on in there. Also, I do believe that there was an issue with certain kinds of macros not working when inserted in the RTE, but I can't remember what the problem was.
    Have you tried to wrap a <form runat="server"> around the whole page, to make sure the macro gets triggered?
    Jan 02, 2011 @ 14:18
    Anthony Candaele
    @Sebastiaan
    I don't understand what you mean with wrapping the page in a <form runat="server"> control, I already use such a control in the masterpage.
    I checked the html of my RichText property of my document type, this is what I get:
    <div umb_macroalias="sidebarWidgets" umb_link="www.actionmaker.be" umb_image="1089" umb_intro="Webmove welcomes a new client" umb_title="In The Picture" ismacro="true" onresizestart="return false;" umbversionid="8d41715e-cb17-40be-bb51-d00ce465c087" umbpageid="1098" title="This is rendered content from macro" class="umbMacroHolder"><!-- startUmbMacro --><span>No macro content available for WYSIWYG editing</span><!-- endUmbMacro --></div>
    In thte wysiwig mode of the richtextbox editor the sidebar widget macro looks like this:
    Jan 02, 2011 @ 14:20
    Anthony Candaele
    @Sebastiaan
    Jan 02, 2011 @ 14:40
    Sebastiaan Janssen
    Never mind, just checked and that won't help! :-)
    I bet in the frontend that the output is something like <?UMBRACO_MACRO ... /> right?
    I believe that if you try to render the rich text area through an XSLT macro, then it's a nested macro and that will not work. Instead, you need to output the the content of the RTE in your template like:
    <umbraco:Item field="sidebarWidgets" runat="server"></umbraco:Item>
    Jan 02, 2011 @ 16:28
    Anthony Candaele
    Phew,
    I finaly got the widget solution as suggested on Hendy Racher's blog implemented:
    The problem I had, was because I didn't push the button 'browse properties' to add the property 'widget' to my macro. This made me second guess, thinking I had to add parameters to the macro for every field.
    After solving this, I found out that Hendy's widget solution is very flexible, one can add all the content for the widget in a RichtText editor field:
    I find this solution more flexible than implemting widgets through a macro container, because widgets can be managed in the content tree. A content administrator just needs to check wich widgets he want to implement on his page:
    Thanks to all community members who assisted me with this: Tim, Kim and Sebastiaan
    Anthony
    Jan 02, 2011 @ 19:05
    Sebastiaan Janssen
    Great, that's much better Anthony, I should've recommended that in the first place, should blog about this some more as well as I'm doing it a little differently.
