  • Touhid 97 posts 117 karma points
    Jan 03, 2011 @ 13:38
    Touhid
    Is it possible in Content section
    In content section i can do this easily:
    Where Position, Date and dir are horizontaly and contains one data in textbox.
    But following this figure Position, Date and dir are  vertically and contains many data in text boxes. And i need  to fooling this, which is urgent for me.
    Can any one help me easily or step by step.
    Touhid
    Jan 03, 2011 @ 14:45
    Lee Kelleher
    Hi Touhid,
    You wont be able to do this out-of-the-box with Umbraco.  You could take a look at the Repeatable Custom Content package?
    The alternative is to create each "row" as a child-node?  So you would have more nodes in your content tree - but it might offer you more flexibility later on too?
    If you are worried about URLs and others accessing the data (of the child-nodes), then you can set a template to redirect to elsewhere (either the parent node, or homepage?)
    Cheers, Lee.
    Jan 03, 2011 @ 16:35
    Rich Green
    Hey,
    Looks like this could be solved with the dynamic grid datatype here http://our.umbraco.org/projects/backoffice-extensions/dynamic-grid-data-type
    However the project states it's under development.
    Rich
    Jan 04, 2011 @ 05:48
    Touhid
    HI Rich
    Thnks for reply but the package cant be downloaded.
    Touhid
