  • Sherry Ann Hernandez 320 posts 344 karma points
    Jan 04, 2011 @ 09:20
    help in umbracoURLAlias
    Hello Guys,
    I used the umbracoURLAlias to remove the parent node from being use in my url.
    Now I'm passing a querystring in my url and I was thinking why is it not removed even if I use a umbracoURLAlias and I also use the seo toolkit from microsoft. Base on the seo toolkit report it found the url
    'http://208.75.250.78/dubai-flora-grand-hotel?hotelID=1' but I don't know where this url is generated because my current url still uses the aspx extension.
    How can I fix this duplicate url being generated?
    Jan 04, 2011 @ 09:26
    Kim Andersen
    Hi Sherry.
    The hotelID=1 parameter is not something that Umbraco generates. It must be somthing that you put on the URL somehow. Either by linking to it, programatically, by a redirect from you code or something fourth.
    /Kim A
    Jan 04, 2011 @ 10:00
    Yes it something from my code. But I wanted to hide it that's why I use the umbracoURLAlias. But I think it doesn't work that way. My question is how can I remove it? (hotelID=1) and how can I ensure that there is no duplicate content or url? because when I run the seo toolkit from microsoft it's telling  me a 404 error for this url
    208.75.250.78/dubai-flora-grand-hotel?hotelID=1 but this url should not be existing because the actual url generated using the umbracoURLAlias is 208.75.250.78/dubai-flora-grand-hotel.aspx?hotelID=1
    I'm not sure if you get what I mean. :D
    Sherry
    Jan 04, 2011 @ 13:32
    Guys,
    I'm really confused on the umbracoUrlAlias.
    The current value of link to document is /hotels/dubai-flora-grand-hotel.aspx
    Then I use the umbracoUrlAlias to remove the "/hotels/" from my url. But then why is it i'm getting a duplicate url which is
    http://localhost/dubai-flora-grand-hotel and http://localhost/dubai-flora-grand-hotel.aspx
    Though if I try to access http://localhost/dubai-flora-grand-hotel it says page not found.
  • Rik Helsen 670 posts 873 karma points
    Jan 04, 2011 @ 14:53
    Rik Helsen
    you're abusing umbracoURLAliasto hide your site structure? why not adjust your site structure?
    also having /hotels/ in your url should be good for seo...
    You're not supposed to use this to mask your site structure, but instead to have a page appear in a second place ...
