  • Touhid 97 posts 117 karma points
    Jan 04, 2011 @ 13:36
    Touhid
    How can user control retreive document property
    Hi All
     I am using Umbraco 4.5.2 Currently I am developing a.Net user control and a document ID will be assed to it. So how can I retrieve all its properties by using its id? I know xslt can do this but do not know how user control do it?
    I know the umbraco.presentation.nodeFactory.Node.GetCurrent() is helpfull but i cant do it completely.
    Can any one help me with complete code.
    Thank you
    Touhid
    Jan 04, 2011 @ 14:15
    Hi Touhid
    I think you should have a look at this WIKI page: http://our.umbraco.org/wiki/reference/api-cheatsheet it should give you a pretty good idea about it if you posses .NET and C# skills :-)
    I also recommend you watch this free episode on umbraco.tv showing how to make a user control based macro in Umbraco: http://umbraco.tv/help-and-support/video-tutorials/introduction-to-umbraco/developer-introduction/using-net-user-controls
    hope this helps.
    Jan 04, 2011 @ 14:32
    Touhid
    Thnks for reply and i have seen that the how to create a user control and i created but i cant apply the code:umbraco.presentation.nodeFactory.Node.GetCurrent()
    Can you help me in details?
    Touhid
