My project consists of a Master Template which is basically a header and a footer. I´ve build a starting page which contains four different subpages and under this should be different produkt pages.
So, i got problems with the logo which is displayed in the header. the path points to media/images/picture.png.
When I created the starting page is displayed. Also when rendering the different subpages the logo is shown, but by creating a produkt page no logo is displayed in the header.
I´ve tried to solve this problem with changing the path to image in //localhost/media/... this works, but of course only on my development machine.
I am new to umbraco, I have to change some text and images in the site. The problem is that I cannot find the Images folder for the images that are in the templates. the folder is not in the Media section. I just want to change the header image but I cannot acces the folder in the server. this is the info in the template:
Links to images in Master Template
Hi, I´m a total Umbraco Newbee.
Thanks for your time.
Hi Oliver,
If you point the image path to '/media/images/picture.png' then this will work for all sub pages.
The inital '/' slash tells the browser to always work from the root of the site and not from the relative page you're viewing.
Cheers
Chris
Hi OliverH,
If I understand your question correctly. Your logo disappears when you are a little deep in the tree structure.
I myself have had the same problem here a while ago. Yet it was not with images that were uploaded in the media library. But with a logo on a server located in a folder called img.
The way I solved my problem was using relative path references. So in my case it was.
instead of simply
Hope it can help you further to find a solution.
/Dennis Aaen
Hi Chris, it works:
Thanks a lot for your speedy help.
Oliver
No problem, glad to help.
<form id="form1" runat="server">
<div id="header">
<center>
<div id="header_centrado_loginlogo">
<div id="header_logo">
<a href="/index"><img style="border:0px;" src="/Images/header_logo.png" /></a>
<div id="header_login">
any help I can get would be greatly appreciated.
