    Jan 09, 2011 @ 16:04
    Anthony Candaele
    implementing language selector
    I am implementing the language selector solution that Tim Geyssen provided on his blog:
    http://www.nibble.be/?p=32
    The problem is that this code is still in the old schema:
    <xsl:template match=”/”>
    <form>
    <select name=”langselection” onchange=”loadPage(this.form.elements[0])” target=”_parent._top” >
    <option selected=”selected”>– Please select –</option>
      <xsl:for-each select=”$currentPage/ancestor::root/node”>
             <option value=”{umbraco.library:NiceUrl(@id)}”><xsl:value-of select=”data [@alias = ‘language’]”/></option>
      </xsl:for-each>
    </select>
    </form>
    </xsl:template>
    I have already converted some code to the new schema:
    <xsl:template match="/">
        <form>
            <select name="langselection" onchange="loadPage(this.form.elements[0])" target="_parent._top">
                <option selected="selected">– Please select –</option>
                <xsl:for-each select="$currentPage/ancestor::*">
                  <option value="{umbraco.library:NiceUrl($currentPage/@id)}">
                      <xsl:value-of select="$currentPage/language"/>
                    </option>
                </xsl:for-each>
            </select>
        </form>
    </xsl:template>
    But I still have an issue with looping through the top level root nodes.
    Currently my site structure looks like this:
    en
       page 1
       page 2
       page ...
    nl
       page 1
       page 2
       page ...
    fr
       page 1
       page 2
       page ...
    With the above converted code though, I'm just getting one top level node: en
    So I guess the line: <xsl:for-each select="$currentPage/ancestor::*">
    does not loop through all my top level nodes.
    How can I loop through all the top level nodes?
    Thanks for your help,
    Anthony Candaele
    Belgium
    Jan 09, 2011 @ 17:15
    Kim Andersen
    Hi Anthony.
    I haven't tried this language selector, but I guess that you need to change the for-each to this:
    <xsl:for-each select="$currentPage/ancestor::root/*">
    /Kim A
    Jan 09, 2011 @ 17:26
    Kim Andersen
    Ohh and by the way you might want to change the value of the option-tags from this:
    to this:
    <option value="{umbraco.library:NiceUrl(@id)}">
    Otherwise all of the values will be same as the current page :)
    And hen the content of the options must be changed from this:
    to this:
    <xsl:value-of select="language"/>
    when you are inside a loop, and want to output anything unique from the nodes, you shall not use $currentPage. If you do so, there'll be output values from the current page where the for-each are being run at.
    /Kim A
    Jan 09, 2011 @ 17:43
    Anthony Candaele
    Hi Kim,
    Thanks, now the language selector shows all options (English, Nederlands, Français) witht their respective values (/en.aspx, /nl.aspx and /fr.aspx).
    The only thing that does not work seemingly is the Javascript file:
    <script language=“JavaScript”>
        function loadPage(list) {
        location.href=list.options[list.selectedIndex].value }
      </script>
    If I select an option in the dropdownlist, nothing happens, I suppose there should be a page reload.
    The html in my dropdownlist looks like this:
    <form><select name="langselection" onchange="loadPage(this.form.elements[0])" target="_parent._top"><option selected="selected">– Please select –</option><option value="/en.aspx">English</option><option value="/nl.aspx">Nederlands</option><option value="/fr.aspx">Français</option></select></form>
    Thanks for helping me out,
    Anthony Candaele
    Belgium
    Jan 09, 2011 @ 18:01
    Anthony Candaele
    The problem with the Javascript is solved. It was rather trivial. I copied the Javascript code from Tim's blog, but apparantly the double quotes are not valid:
    </script>
    So I just replaced the invalid double quotes and now my language selector works perfectly :)
    <script language="JavaScript">
    Thanks for helping me out Kim,
    Anthony
    Jan 09, 2011 @ 20:01
    Kim Andersen
    You are very welcome Anthony :)
    /Kim A
  • dominik 711 posts 733 karma points
    Feb 24, 2011 @ 16:44
    dominik
    one question
    is it possible to jump to the nearest element if no translation is available
    for example:
    I got two languages english and german and my structure is like:
    en/products/cars/car-one.aspx
    but in german there is only:
    de/products/cars/ available but not car-one.aspx?
    The user should be redirected to the de/products/cars/ and not to the root directory like it is at the moment
    Mar 04, 2011 @ 10:13
    dominik
    Can somebody please help?
