    Jan 10, 2011 @ 10:24
    Anthony Candaele
    implementing a Master Content Type
    I'm implementing the News functionality as implemented in the Business Website Starter Pack developed by Dan Drayne:
    http://our.umbraco.org/projects/starter-kits/business-website-starter-pack
    In this starter pack, Dan has implemented the News Area and News Item content type as children of the Textpage content type.
    The Generic Properties tab of the News Area and News Item content types states:
    "This content type uses * Textpage as Master Content Type. Properties from Master Content Types are not shown and can only be edited on the Master Content Type itself."
    How can I create this Master Content Types? I have include a screenshot from the Business Website Starter Pack:
    Thanks for your help,
    Anthony Candaele,
    Belgium
    Jan 10, 2011 @ 10:38
    Hi Anthony
    To create a master document type you just create a document type as you normally would. You can call it "ContentMaster" or whatever makes sense and then you create another document type - in the dialogue you simply just choose, which document type this document type should inherit it settings from.
    When it's created and you click on it you will see the text automatically appears.
    In Juno it's also possible to add extra fields on a master property.
    If you for instance know that you'll have a tab called "content" and on alle your pages you will need a textfield for headers you can defines this on the master document type. As it is now you're not able to add anything to the content tab on the inherited document types...so if you for instance know that you need to have a rich text field on you "textpage" document type and you would like to add it to the "content" tab, which is defined on the parent you can't do it in 4.5.2 - but in 4.6 you can! :-) (this is just some bonus info :-))
    Jan 10, 2011 @ 11:03
    Anthony Candaele
    Hi Jan,
    Thanks for the information, I was able to create two document types under the Textpage document type.
    greetings,
    Anthony
